Author Topic: Changing Connector Type Acssociation -> Trace  (Read 6256 times)
Michel777
« on: December 08, 2015, 07:44:47 pm »
how to change the type of Connector  "Association" -> "Trace" ?
Thanks a lot in advance,
Michel
Re: Changing Connector Type Acssociation -> Tra
« Reply #1 on: December 08, 2015, 07:55:43 pm »
FWIW,  trace is not a Type, it is (effectively) a metatype.
The Change Connector type only changes types of connectors not metatypes (I wish it would - so many users ask the same question as you).
You need to
1) Change the type from Association to Abstraction
2) Add the trace stereotype to the new Abstraction
Hope that helps.
« Last Edit: December 08, 2015, 08:00:06 pm by PaoloFCantoni »
