Author Topic: How to set default connector style  (Read 11080 times)
thed0ctor
« on: November 06, 2014, 12:10:39 pm »
is there a way to set the default connector style? I'd like it to be square orthogonal by default instead of having to always change it.
Re: How to set default connector style
« Reply #1 on: November 06, 2014, 09:28:20 pm »
IIRC, still not. Has been requested quite some times. Try to search the Suggestions forum.
« Last Edit: November 06, 2014, 09:28:41 pm by qwerty »
« Reply #2 on: November 07, 2014, 09:35:36 am »
Currently you can only set the default to Direct, Auto-routing or Custom, not Bezier, or any of the tree styles or orthogonal styles. But if you create a stereotype in a profile, you can define any line style to that stereotype. Search the help for _lineStyle for guidance.
« Reply #3 on: November 10, 2014, 04:37:49 pm »
and this hasn't changed in EA 12
thed0ctor
« Reply #4 on: November 15, 2014, 05:52:54 am »
Could you direct me to the article? I tried searching _lineStyle but couldn't find anything
« Reply #5 on: November 15, 2014, 06:37:27 am »
Open the Help/Help Contents from EA and then Search for _lineStyle. One hit...
« Reply #6 on: March 16, 2015, 10:34:32 pm »
I wrote an EA-Matic script to configure my own default line styles per connector type and update all the connectors in a diagram to said default styles: Configure your own default line styles in Enterprise Architect with EA-Matic
« Reply #7 on: December 11, 2015, 07:50:29 am »
not in 12.1
« Reply #8 on: December 11, 2015, 08:54:56 am »
not in 12.1
You should set that as your signature  ;D
