Author Topic: New Tool to Generate Custom Word Documents  (Read 4627 times)
Report Developer
« on: October 19, 2009, 04:52:47 am »
Provide an EA project and the word document of the output file and I will do the rest.
http://www.rbdatatech.com/BDG%20for%20Enterprise%20Architect.html
Please make comments on this product.
Report Developer
Re: New Tool to Generate Custom Word Documents
« Reply #1 on: October 22, 2009, 11:02:11 am »
For professional services, contact me at [email protected]. Services starting from $40 US or more depending on difficulty for the custom report.
« Reply #2 on: October 22, 2009, 05:08:23 pm »
I would love to comment on the product, but the link you provided brings me to a website that only shows a movie; which puts me of right ahead.
I even tried visiting the http://www.rbdatatech.com, but that seems to be broken as well, no trace of a report generator for EA.
Report Developer
« Reply #3 on: October 28, 2009, 07:13:39 am »
As requested , BDG beta
http://www.rbdatatech.com/bdg.zip
Let me know what you all think. The report template can be improved to match your design.
fanweik
Some requirements for implementation by BDG
« Reply #4 on: October 28, 2009, 09:12:35 pm »
Hello, Report Developer,
  I have following requirement, Could you please make sure that your software can meet these requirements?
  I want to create a document from the ea project. And in this doc I need to have a special cover on which some user defined document variables(I invoke this concept from MS word file) like document name, author, project name, version and so on will be automatically put to some areas.
Next point is, on second page, we need to put a table of history which describes by whom and when this document is changed. Beside that we still need to create some categories for all the figures, tables and requirement keys like TOC(Table of Content).
The linked document should also be put to the final document.
Should I install ms word in advance?
Meanwhile I have downloaded your sample of BDG for EA, but when I start to generate Doc after loading files under config , I always get some XML consistency errors though the docx is finally created.
Wei
« Last Edit: October 28, 2009, 10:15:34 pm by fanweik »
Report Developer
« Reply #5 on: October 28, 2009, 10:58:41 pm »
Did you use the example EA file I provided?
If you send me a sample EA file I can test the application locally and provide an update.
Send me also a sample word doc that you want to be the final format - I can investigate the changes needed to support your custom report.
Report Developer
« Reply #6 on: October 29, 2009, 12:35:08 am »
XML problem is fixed.
