Author Topic: Not able to use JDWP in EA 9.3  (Read 19901 times)
Re: Not able to use JDWP in EA 9.3
« Reply #15 on: December 03, 2015, 06:12:37 pm »
License keys don't depend on the version of EA.
You just need to upgrade, you should not need to do anything with regards to the license.
akshit
Re: Not able to register with a valid key
« Reply #16 on: December 03, 2015, 09:05:41 pm »
But then why I am not able to register my product. I have a trial version and I tried entering the key in "Register and manage license key". Is this method right?
« Reply #17 on: December 03, 2015, 09:40:18 pm »
You should not install the trial version.
The trial version is a different application altogether.
You have to download the new installer from the registered user section of the website:
http://www.sparxsystems.com/registered/reg_ea_down.html
akshit
« Reply #18 on: December 04, 2015, 03:10:42 pm »
Thank you. It was helpful
Nishtha
« Reply #19 on: December 14, 2015, 09:10:07 pm »
When i clicked on the link for installing EA, it asked for Authentication Required. but it is not taking the username and password that i received at the time of registration. please help.
« Reply #20 on: December 14, 2015, 09:20:53 pm »
It uses the username and password that was sent to you together with your license/renewal.
That is different from the username/password for this forum, or the community site.
Aaron B
« Reply #21 on: December 15, 2015, 10:40:08 am »
A current maintenance subscription is required to access registered downloads.  12 months maintenance is provided from the original date of purchase, after which you must purchase renewals for continued access to priority support and registered software updates.
For more information about maintenance renewal, see:
http://www.sparxsystems.com/products/ea/license_info.html#renewal
For any further enquiries regarding maintenance subscription, please contact [email protected].
As Geert mentioned, the logins used for the forum and community website are completely different systems.
akshit
issue in remote debugging
« Reply #22 on: December 18, 2015, 08:09:24 pm »
I have a project testset  built on server and I run it in debug mode(on web logic server) and  connect enterprise architect to the testset(in debug mode). Then I run a script to start the data flow. My objective is to debug the code which is running on a remote machine. For that I have tunneled  local machine's port to remote machine's port and have specified that port number in analyzer script. After the flow is started, it should hit the breakpoint. But EA responds with a message: “no reply to request jdwpCmd_ThreadName”. What does this mean? Am I doing something wrong?
If anything you felt is left unexplained on my side please inform.
Thanks in advance.
akshit
« Reply #23 on: December 18, 2015, 08:32:42 pm »
[103032083]      jdwp error: errcode 20, cmd(010b) jdwpCmd_ThreadName
this is also an error appearing
