Author Topic: UnFiltered Task list window (ALT-4)  (Read 13009 times)
Chris_Reynolds
  • Poets have been curiously silent about cheese.
« on: August 26, 2003, 02:04:25 pm »
The current maintenance window with its four tabs provides a very fragmentary way of looking at the things to do.
In trying to use this, I have found that I can only work if I use one of the tabs and write reports outside of EA to assemble the tasks into a meaningful work plan.
IMHO it would be a better user interface if that window was untabbed with a single grid and a filter panel that let you see your preferred sub-set (e.g. check the 'Issues' checkbox if you want to see issues or even uncheck the completed checkbox to hide the completed tasks.)
If it also allowed you to list the tasks of the children of the currently selected model element then you could select a package and see all the pending tasks in that package.
Chris_Reynolds
Re: UnFiltered Task list window (ALT-4)
« Reply #1 on: August 26, 2003, 02:07:21 pm »
Of course, all the same arguments can be applied to the Test Window (ALT-3).
