Author Topic: Problem: adding a taggedValue to a Connector  (Read 3959 times)
Hermes
« on: November 04, 2009, 03:28:19 am »
Dear All,
I'm tring to write an addin in c# to manage a UML customized metamodel with EA.
But i got a strange exception when I try to analize connectors:
It seems that i'm not allowed to get/add tagged values to this items. :(
this are few lines from my code:
foreach( EA.Connector conn in child_req.Connectors )
                if (conn.Stereotype == AppConfig.EAP_MY_LINK_STEREOTYPE)
                    EA.TaggedValue link_status_tag = BaseControl.GetTaggedValue(conn.TaggedValues, AppConfig.TAGVAL_MYLINK_STATUS);
                    if (link_status_tag == null)
                        //exception starts HERE
                        BaseControl.AddTaggedValue(conn.TaggedValues, AppConfig.TAGVAL_MYLINK_STATUS, AppConfig.EAP_TAGGEDVALUE_TYPE, AppConfig.MYLINK_STATUS_PROPOSED);
and this are two helping functions that i call in the above snippet:
  public class BaseControl
        public static bool AddTaggedValue(EA.Collection coll, String name, String type, String value)
            EA.TaggedValue tag = GetTaggedValue(coll, name);
[highlight]
 //exception raised HERE[/highlight]
            if(tag==null)
                tag = (EA.TaggedValue)coll.AddNew(name, type);
            tag.Value = value;
            if (!tag.Update())
                AppConfig.last_error_msg = "Cant add TaggedValue [" + name + "],[" + type + "],[" + value + "]";
                return false;
            return true;
        public static EA.TaggedValue GetTaggedValue(EA.Collection coll, String name )
            EA.TaggedValue tag = null;
            try
                tag = (EA.TaggedValue) coll.GetByName(name);
            catch (Exception)
                return null;
            return tag;
when I try to run this, i got this:
Impossibile eseguire il cast di oggetti COM di tipo 'System.__ComObject' in tipi di interfaccia 'EA.TaggedValue'. L'operazione non è stata completata perché la chiamata QueryInterface sul componente COM per l'interfaccia con IID '{EF08950B-949E-435F-84A3-A59E3106C3BF}' non è riuscita a causa del seguente errore: Interfaccia non supportata. (Eccezione da HRESULT: 0x80004002 (E_NOINTERFACE)).
that Translated in English says that it is not possible to cast the returned value [from Collection.AddNew()] in the EA.TaggedValue inteface. Operation not completed from the QueryInterface because the interface is not supported  :(.
I use the string type: "TaggedValue" when calling the Collection.AddNew() method.
( ie: AppConfig.EAP_TAGGEDVALUE_TYPE = "TaggedValue" )
Note that: my code tries to insert a new tagged value because it not finds the specified taggedValue... but it should exists in the model. (I've created manully in a diagram using a drag&drop mode).
Why this happens? could someone helpme please?
Thankyou :)
/D
Re: Problem: adding a taggedValue to a Connector
« Reply #1 on: November 04, 2009, 08:21:50 am »
Look for EA.ConnectorTag (or something similar)  It is not an EA.TaggedValue.
Hermes
« Reply #2 on: November 04, 2009, 10:00:09 pm »
Great! it worked  :)
Thankyou!
