Author Topic: SCC Provider?  (Read 11853 times)
iran
SCC Provider?
« on: September 23, 2003, 02:19:29 pm »
Anyone using CVS as the version control mechanism for EA?  I can't seem to get CVS to show up in the SCC Provider window when I select the checkbox to put a package under source control. CVS works find from the command line.  I also choose the local path to transfer files as the "checkout" checkout directory for cvs.
iran.
Tjerk
Re: SCC Provider?
« Reply #1 on: September 24, 2003, 01:27:32 am »
Hi Iran,
Do you have a SCC Provider installed for CVS? Such a driver is needed to work with CVS. Examples of such programs are: Jalindi Igloo, PushOk CVS Proxy or Tortoise.
Greetings,
Tjerk
iran
Re: SCC Provider?
« Reply #2 on: September 24, 2003, 09:17:32 am »
yes, I have tortise installed.  I am installing the ones you mentioned now. will let you know what happens.  Thanks for the response.
--iran.
iran
Re: SCC Provider?
« Reply #3 on: September 25, 2003, 08:45:38 am »
I got it working by using a new project with no references to cotrolled files by serendepity.  I also was able to get a SCC interface for Telogic CM Synergy. One note is to ask you vendor or google, if you tools supports SCC directly.
--Iran.
