Author Topic: Problems with exporting to XML  (Read 9263 times)
smidz
« on: October 07, 2003, 11:24:56 pm »
I have little problem (maybe missing functionality) with EA and exporting packages to XML. I would like use exporting packages to xml for synchronizing work with other designers. Problem is, that during export some information from diagrams are lost.
For example: I have association link between 2 tables, source and target roles are specified. After export, there is no information about source and target roles in XML file (... after import this information is missing in diagram too). I tried different settings for export but without succes.
Another bug is, that during import XML file some national characters are replaced/ (Czech charset, Central Europe, win 1250).
I also miss function for export/import diagrams only, not whole packages.
My version of EA is Unicode, 3.60, build 646.
DC
Re: Problems with exporting to XML
« Reply #1 on: October 27, 2003, 06:22:57 am »
We are also experiencing similar problems. After inporting the xml into a new project we find that all flow links between elements and have disappeared.
This problem has only arisen since we started using visual source safe with EA. Are you using source safe?
