Author Topic: Probably these are not requests....  (Read 7892 times)
bbates
« on: February 10, 2004, 12:07:55 am »
Usually if I poke around I might find the answer.
If I rename the source code file I can't seem to be able to resynch it. The system keeps asking for the "old" name.  I wonder if there is a way to change the name.
The property note is a good idea. Can't seem to put them on the top of sequence diagrams. Also can't figure out how to change/get rid of the create date.
When making documentation I couldn't change the page orientation. Thought about doing it as a rtf template but can't find the "resources" tab the help file talks about.
This is a great product. I am well into doing a 1500 line vb6 conversion project and another project with it. I am thinking about writing a CSLA (Rocky Lhotka's framework) extension for it.
mbc
  • Embedded software developer
Re: Probably these are not requests....
« Reply #1 on: February 10, 2004, 01:09:04 am »
1) Select the class and change "Filename" under Class Settings in the Properties docked window (usually on a tab in the lower right of your screen).
2) I don't quite get your question.
3) The Resource View tab is usually right under the Project View tree (upper right of your screen).
Mikkel
bbates
« Reply #2 on: February 10, 2004, 07:43:05 pm »
1) Yes I found it. I guess that sneaky Properties window disappeared. I was doing a "class properties" (element /properties or alt-enter) which is different than
the (view/properties or alt-1).  It would be nice to have the alt-1 properties on the context menu (right click) of the class.... for idiots like me.... Forget it. Its a nice window to have open....
2) The property note (Diagram/insert property note) is what I am referring to here.  Now that I know that projects have properties I have it mostly working. Only problem is the "created" is stuck on 8/13/2001. Is there a way to change or get rid of this entry?
3) Found the resource view.  Yup I should have looked more at that View Menu <g>.
I am happy now.....]
