Author Topic: Output when using VS Express 2008  (Read 4188 times)
floerio
« on: November 05, 2009, 06:29:40 pm »
Hi!
I am using Visual Studio Express 2008. For debugging purpose, I want to print some things on the output console of VS.
I am using something like this:
case "Connector":
    EA.Collection Connectors = e.Connectors;
        foreach (EA.Connector s in Connectors) {
              System.Console.Out.WriteLine("contextcnt " + e.Name);
                        x.Add(s); }
                    break;
But on the output window within VS, nothing appears. Nevertheless, internal C# messages are printed. e.g. when the system is started.
Info: I am writing a plug in, so the whole thing is executed as DLL. Is this a problem?
Cheers,
   Oliver
Re: Output when using VS Express 2008
« Reply #1 on: November 05, 2009, 07:43:06 pm »
Have already tried to set a breakpoint to see if the code execution even gets there?
Makulik
« Reply #2 on: November 05, 2009, 10:48:58 pm »
Yup, definitely! Usually there won't be any console to write your output to, when running as EA AddIn (I just guess that's what you're trying to do). I would recommend to either use Debug.Out to see your messages in the VS debug window when running your DLL in debugging mode, or to use a logfile.
Günther
Aaron B
« Reply #3 on: November 06, 2009, 02:41:58 pm »
Or you could try writing to EA's output window from your Add-In using Repository.WriteOutput().  For Example:
Repository.WriteOutput("System", "Hello World", 0)More methods are available for interacting with EA's output window on the EA.Repository object, including CreateOutputTab(), EnsureOutputVisible(), and ClearOutput().
