Author Topic: Focus Request on Attribute Constraint Tab  (Read 6250 times)
darryl_staflund
  • "mmmMMMmmm!!!   UML!"  -- Attributed to Homer
« on: March 26, 2004, 08:56:25 am »
Hi there,
I would like to request that on the Constraint tab of the Attributes dialogue box, focus be returned to the 'Constraint' input field when the New button as pressed.  In EA 400 (723), the screen is designed so that the user follows the following sequence of events when adding an attribute constraint:
a.  User enters the constraint in the Constraint input field.
b.  User selects constraint type from the drop-down box.
c.  User presses New and add a new constraint
When the user presses New, focus is still placed on the last element worked with (i.e. the Constraint Type dropdown list.)  This is not intuitive and requires me to be cycle through the tabs or use my mouse to position cursor back on the Constraint input field.
Darryl Staflund
Re: Focus Request on Attribute Constraint Tab
« Reply #1 on: March 26, 2004, 10:48:42 am »
