Author Topic: C# Plugin: Product Line Feature Diagram in UML  (Read 57115 times)
Edoardo
Re: C# Plugin: Product Line Feature Diagram in UML
« Reply #30 on: November 04, 2009, 12:09:19 am »
I would try to create a DiagramLink and set the layout options on that one.
Done, but the layout option entry is not documented, I don't really know how to set it.
I tried something but it has no effect at all.
« Last Edit: November 04, 2009, 12:09:40 am by e.varasi »
Edoardo
« Reply #31 on: November 09, 2009, 09:08:11 pm »
Hi again, please help me with this
when I try to connect a class to another using "composition" with this statement:
Code:
EA.Connector con1 = (EA.Connector)associazione.Connectors.AddNew("", "Composition");
con1.SupplierID = madre.ElementID;
con1.Update();
in my diagram appears an aggregation relation instead (a white diamond)
How can I create a real composition connector (black diamond)?
thanks a lot
« Reply #32 on: November 09, 2009, 09:17:13 pm »
It could be that you have to set the aggregationKind of the connectorEnd to the appropriate value ("Composite").
Edoardo
« Reply #33 on: November 09, 2009, 09:55:45 pm »
Sorry, I cannot find the aggregationKind entry in con1.SupplierEnd
« Reply #34 on: November 09, 2009, 10:11:49 pm »
[size=18]...[/size]
[size=18]...[/size]
Hi Edoardo,
According to the EA Help, "Composition" is not a valid type here.  The Connector Type needed is "Aggregation"
The AggregationKind is represented by the Aggregation attribute of the appropriate ConnectorEnd.
Valid values are:
0 = None
1 = Shared
2 = Composite.
Be warned though, that your "appropriate end" may be affected by the way you have instructed EA to draw Aggregations.
The general advice by long-term users is to avoid EAAggregations and use ordinary Associations appropriately adorned.  If you do a search for Aggregations you find more on this.
Edoardo
« Reply #35 on: November 09, 2009, 10:14:49 pm »
[size=18]...[/size]
[size=18]...[/size]
Hi Edoardo,
Valid values are:
0 = None
1 = Shared
2 = Composite.
Thanks a lot, this solved my problem!
