Author Topic: FRQ: merge elements  (Read 7547 times)
angel-o-sphere
FRQ: merge elements
« on: May 14, 2004, 07:29:54 am »
I often have the problem that I have two elements of same UML:type but with different names, which are in fact the same element.
They are probably in different packages because they got created by different persons.
I like to suggest a option to merge those two elements.
That means all usages of one or the other will be replaced by the new merged version.
Imagine a diagram with screen S and component A denoting that A realizes S and a second diagram with use case U and a component B denoting B realizes U.
Now I want to merge A and B to C and the two diagrams should now both get updated to display C instead of A or B and the new C should have all features, except name merged.
That means C links now to two artifacts: S and U.
The user has to pick a new name and a new package for C ... or you just take the oldes elements features and let the user move and rename it later.
  angel'o'sphere
« Last Edit: May 14, 2004, 07:33:37 am by aos »
jps
Re: FRQ: merge elements
« Reply #1 on: May 14, 2004, 08:09:21 am »
I not only second this, but would love to see support for "Refactoring" in general.
In particular would be the ability to extract a super class from a set of methods in a given class.
Bruno.Cossi
« Reply #2 on: May 14, 2004, 11:04:22 am »
I second this whole-heartedly.
sargasso
« Reply #3 on: May 16, 2004, 04:26:07 pm »
Just to link this to the previous expounding of this request.
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.cgi?board=suggestions;action=display;num=1069178315;start=2#2
Bruce
p.s.  Have I mentioned multiple select recently?
« Last Edit: May 16, 2004, 04:27:46 pm by sargasso »
