Author Topic: Simple chinese support  (Read 6477 times)
hiee91511
« on: May 15, 2004, 07:47:34 am »
I have download EA 4.0 trial .But I found it can't run with the simple chinese os(The display error even I have changed the option).
hiee91511
Re: Simple chinese support
« Reply #1 on: May 19, 2004, 01:45:52 am »
The Difference between Unicode version and the non UniCode Version
The major difference between the Unicode versions of Enterprise Architect and the non Unicode versions is the Unicode versions have support for the character sets available through the Unicode standard which includes support for most languages. Typically the file size for the Unicode versions are slightly higher than the file size for the normal version ~300Kb.
where can I download the unicdoe version?Thanks.
« Last Edit: May 19, 2004, 02:09:55 am by hiee91511 »
« Reply #2 on: May 19, 2004, 08:42:12 am »
Probably this is available only to registered users. Maybe you should write to Sparx directly and see if they can provide a Unicode trial?
« Reply #3 on: May 19, 2004, 03:22:31 pm »
The unicode trial is available on the same page as the (non-unicode) trial.
http://www.sparxsystems.com.au/ea_downloads.htm
hiee91511
« Reply #4 on: May 19, 2004, 08:23:22 pm »
Thanks everyone
