Author Topic: Changing Stereo Type glyph  (Read 5343 times)
Rolland
« on: July 08, 2004, 01:30:31 pm »
Is there any way to change the little graphic in the upper left of Artifacts or Node (or other object for that matter) so that when you create your own stereo type that picture will appear there.  For example, if a server stereotype is indicated, a little server appears in the corner.  How can I change that graphic to be something else? Thanks
Re: Changing Stereo Type glyph
« Reply #1 on: July 09, 2004, 12:45:36 am »
Goto Configuration/Stereotypes, select the appropriate stereotypes, place your own icon.
Rolland
« Reply #2 on: July 09, 2004, 06:30:24 am »
Thank you for you response.  But replacing the entire metafile is not exactly what I want to do.  I want use an existing shape and just change the little icon, like the server icon when the node's stereo type is changed to something else.  I believe this is done internally using the UserImages.bmp file.
