Author Topic: Close current diagram: Ctrl+F4 / Ctrl+W ?  (Read 4830 times)
mikewhit
  • Accessing ....
« on: November 05, 2004, 05:03:21 am »
It would be very convenient to have a keyboard shortcut to close the current diagram, rather than having to mouse down to do it, and particularly if you've ended up with several superfluous open diagrams.
Under Windows UI guidelines, this would be Ctrl+F4 (already available for the dockable windows) or Ctrl+W (used to be the case for Visual C++ at any rate, IIRC).
Takeshi K
    • Sparx Systems Japan
Re: Close current diagram: Ctrl+F4 / Ctrl+W ?
« Reply #1 on: November 06, 2004, 12:02:57 pm »
You can assign Ctrl+W or Ctrl+F4 to close current diagram
by 'Tools'->'Customize'->'Keyboard tab'.
(Currently Ctrl+F4 is assigned to other feature, so
you must re-assgin the key conbination.)
t-kouno
t-kouno
mikewhit
  • Accessing ....
« Reply #2 on: November 08, 2004, 02:04:40 am »
Thanks - but I was also pointing out that the current Ctrl+F4 functionality should apply to current diagram as well as docked windows - though I can't quote chapter & verse on Windows Application Interface Guidelines !!
I thought Ctrl+F4 was something like "close MDI child window with focus" which would apply to the current diagram too.
« Last Edit: November 08, 2004, 02:36:35 am by mikewhit »
