Author Topic: Renaming a class used as an operation argument  (Read 7940 times)
yves.carrier
« on: January 04, 2005, 01:24:19 pm »
Hi everyone,
I am pretty new to EA and found that whenever I rename a class that I peviously used as an argument for an operation, the type of the argument will not follow the new class name. Anything I am not doing right?
Yves.
Re: Renaming a class used as an operation argument
« Reply #1 on: January 06, 2005, 01:52:25 am »
Just tried it here. Works as designed. Renaming the class also changes the parameter. I use build 741. Maybe you can give the steps to reproduce the error?
yves.carrier
« Reply #2 on: January 14, 2005, 08:03:49 am »
Hi Thomas,
Sorry to have been so long to reply, I was assigned on a totally different duty for the last 2 weeks or so. Now, here we go...
I should have mentioned in my first message  that the problem occurs for messages used as part of sequence diagrams. When a class modification is done, the messages using this class are not synchronized (namely, return types, maybe others as welll) unless you reselect the message and re-submit the same class method as the message type.
Yves.
« Reply #3 on: January 17, 2005, 04:10:54 am »
You're right.  So it's likely a bug and you should submit a bug report.
yves.carrier
« Reply #4 on: January 17, 2005, 05:08:01 pm »
I did so. Thanks, Yves.
