Author Topic: Interbase/Firebird Autoincrement Generator/Trigger  (Read 5723 times)
JLove
« on: December 23, 2004, 03:02:18 pm »
The Data Modeling generated SQL DDL for an Interbase/Firebird database with an Autoincrement Field in a Table does not correctly implement support for a Generator and corresponding Trigger.
Using the "Drop Table" checkbox to generate the SQL DDL creates a line in the SQL:
DELETE FROM RDB$GENERATORS WHERE RDB$GENERATOR_NAME='TableName_FieldName_INC';
However, the Generator (and corresponding Trigger) is not created in the script.  The create SQL DDL should be something like this:
CREATE GENERATOR "TableName_FieldName_INC";
SET GENERATOR "TableName_FieldName_INC" TO 0
SET TERM ^ ;
CREATE TRIGGER "TRG_TableName_FieldName" FOR "Activity"
ACTIVE BEFORE INSERT POSITION 0
AS
BEGIN
 IF (NEW."FieldName" IS NULL) THEN
   NEW."FieldName" = GEN_ID("TableName_FieldName_INC",1);
END
SET TERM ; ^
« Last Edit: December 23, 2004, 03:07:33 pm by JLove »
James Love
Software Engineer
SenDx Medical, Inc.
A Division of Radiometer Copenhagen
hd
Re: Interbase/Firebird Autoincrement Generator/Tri
« Reply #1 on: December 23, 2004, 05:18:37 pm »
Thanks for your note - we'll look in to that.
mikewhit
  • Accessing ....
NEWS?- Interbase/Firebird Autoincrement Generator
« Reply #2 on: January 24, 2005, 02:35:08 am »
News please, Sparx !
We are currently working around a number of issues regarding procedures and triggers on InterBase, which were reported in detail by a colleague in September, via email.
If this is still an issue in build 744 then it would be good to have an idea when the fix might become available.
Thanks.
