Author Topic: Configurable columns for Relations Window  (Read 4029 times)
« on: January 26, 2005, 10:38:01 am »
would it be possible to configure the Relations Window so you can see additional attributes like source and target role?
(BTW: click a bit right of the right hand border of "In Diagram" and you unveil ID and DestID - two hidden columns :o)
sargasso
Re: Configurable columns for Relations Window
« Reply #1 on: January 27, 2005, 02:16:49 pm »
I know this is taking thomas' request to the extreme but...
I would like to see a consistent and user tailorable listview used for all lists in EA.
For example, because there are so many overrides in C# classes, and the Operations listview in the General tab doesn't show the parameters, it takes 3 clicks on each operation to select the operation,open the parameters tab, check if the override I want, and then click bak on the general tab to pick the next one.  It would be so much easier if the list showed the parameters as a list of types, like in the diagram.
bruce
« Reply #2 on: January 29, 2005, 11:27:17 am »
Yes. A general way to configure list views would be much appreciated!
