Author Topic: Invalid C# code synchronization for initial values  (Read 4132 times)
Drc
« on: April 27, 2005, 07:12:43 am »
I have problem with synchronization c# code to EA model. When I define field in class with some initial value, something like this:
[NonSerialized]
private static ILog Log = LogManager.GetLogger(typeof(XY));
After reverse engeneering to EA model, initial value is set only to: LogManager.GetLogger
so when code generation is run again, result in code is:
what of course wrong for compiler.
But for initial values like Hashtable, ArrayList etc. everything is correct.
Re: Invalid C# code synchronization for initial va
« Reply #1 on: April 27, 2005, 03:11:17 pm »
What build of EA are you using?
I just checked and unless I'm mistaken, any build after 745 should do this correctly.
Are you still a registered user and can upgrade to the most recent version?  If you are then I suggest that you do that.
Simon
Drc
« Reply #2 on: April 28, 2005, 01:13:39 am »
You are right, I have version 4.50 build 744, after downloading the latest version synchronization seems to be ok. Thanks.
