Author Topic: Code Generation  (Read 4400 times)
Marcelo
Code Generation
« on: July 20, 2005, 06:58:26 am »
Does anyone know how to export a parameter´s note from a class´ operation, when I use the Generate Code(forward engineer).
         Marcelo.
Chris Brandt
Re: Code Generation
« Reply #1 on: July 25, 2005, 09:20:25 am »
I assume by Parameter, you mean Attribute (in UML lingo). If that's the case, the %attNotes% field substitution macro is what outputs the notes.
Are you modifying a language template? Or just having trouble with simple forward engineering?
Chris.
Re: Code Generation
« Reply #2 on: July 25, 2005, 04:09:24 pm »
I assume that http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=general;action=display;num=1121878542;start=1#1 didn't answer your question.
What is it that you're trying to do other than that?
Simon
