Author Topic: bug with communication diagram redrawing  (Read 4534 times)
soril
« on: July 25, 2005, 06:43:41 pm »
When opening some of the communication diagrams I created earlier, the objects are not drawn correctly. More specifically, I have several "collaboration message arrows objects" going from an object to another one. Here is the steps I used for reproduction:
1) Create a communication diagram with several links ("collaboration message arrows objects")
2) Place the messages with the arrows the way you like.
3) Save the project, Close it and re-open it.
4) open the original diagram you created
5) The objects are not drawn the way they were when you saved them, they're misaligned !
6) Click on a misaligned "collaboration message object" and the message will automatically change its location to the correct position, but I have to move the mouse a bit or else it will go back to its original (and wrong) location.
If I save the project and close/re-open it, the same process will go over and over again. That means I have to re-set the location of those objects everytime I open the diagram/project
I would appreciate hearing from you, what can I do for it and anybody experienced something similar?
Sébastien
Stephen
Re: bug with communication diagram redrawing
« Reply #1 on: August 02, 2005, 04:05:32 am »
I'll add a vote for this problem. I can't even control which way the arrow points when I first add the message to the diagram.
It usually aligns with the notional direction of the link and the message direction. But too many arrows point sideways when associated with a vertical line.
Sometimes moving the link object further apart moves the arrow to the correct direction, but sometimes I have to move, and move, and move the object. Diagrams start to look ridiculous. :o
