Author Topic: Exponential Recursion in Hierarchy View  (Read 4312 times)
fwoolz
« on: August 04, 2005, 10:23:05 am »
I have a bunch of requirement elements (several hundred) in a model. The requirements are nested such that there are requirements that own other requirements that own other requirements...and so on, similar to the structure of a written specification. Given that the hierarchy view shows both "owns" and "owned by" links (recursion!), a fully expanded tree at greater depths results in an exponential explosion in the size of the tree, enough to cause EA to use about 100% of the CPU and > 200 Meg of memory (and climbing) before I shut it down (this happened at a depth of 10 for the subject model). I should add that this wasn't an academic exercise; I had set the depth to 10 without thinking, then tried to expand the tree.
I don't know off-hand how difficult it would be to implement or what the shortcomings might be, but might it not be a good idea to omit the "owned by" branch for all but the topmost node in the tree?
BTW--I'm using EA 5.0, build 768.
Cheers,
Fred Woolsey
Interfleet Technology Inc.
Re: Exponential Recursion in Hierarchy View
« Reply #1 on: August 04, 2005, 04:17:10 pm »
[size=13][SNIP][/size]
Cheers,
Yes, Fred, I've also noticed this.  Both strategies should be options (since multiple inheritance is growing in usage).
If we're talking suggestions, it would be good to be able to pick a node in the hierarchy and then ask EA to re-plot the hierarchy for that node (with -possibly- new options).  Best of all would be the ability to do this in "a new window" so that you could investigate specific nodes while retaining the original hierarchy.
Cheerz,
