Author Topic: Connect to a SQL Server Data Repository  (Read 4012 times)
farojas
« on: August 22, 2005, 03:36:05 pm »
Hi, I've a EA Corporate Edition, Program Version: 4.00.722 (Buid 722). I need use the function to connect to a SQL Server Data Repository.
I've idea about of the exists of a script, that i must run in a clean data Base. But i don't have this scripts...
From where i can download this scripts...
and if thare are something more that a must know.
I want to create and open models, in a Repository in SQL Server
AshK
Re: Connect to a SQL Server Data Repository
« Reply #1 on: August 22, 2005, 11:09:13 pm »
Hi Farojas,
Please refer to the following help section:
http://sparxsystems.com.au/EAUserGuide/settingupdatabasemodelfile.htm
If you have further issues, please send an email to out support address.
Ash
farojas
« Reply #2 on: August 23, 2005, 09:03:44 am »
OOhhh... thanks...
just i do it.....
Thanks You Very Much
farojas
« Reply #3 on: August 23, 2005, 01:38:31 pm »
One time connected a proyect EAP with a SQL Server Data Repository. I connect the packages of the project EAP with a SCC (Source Code Control), in this case WinCVS.
But if i connect the project EAP with a Data Repository, and then puts the package in WinCVS, the EA send message of Error, and close the program.
If i connect the project EAP with WinCVs and then with a Data Repository, work no problem.
My question is: Why EA produce this error??
Bad configuration ??..  o this way work???
