Author Topic: Test Cases on Lower Level Composite Use Cases  (Read 4078 times)
BSchuyler
« on: September 18, 2005, 12:59:40 pm »
I'm not sure if this is the right location to report a software problem or issue.  Our company has one person which maintains the Registered Userid so I cannot report problems/bugs through "Report a Bug" web page.
I've run into a problem when adding Unit Test Cases on lower level composite Use Cases (e.g., a Use Case under a Use Case used for grouping more than one Use Case together for business functions).  The Test Case is produced on the RTF output file for the top level Use Case(s), but the lower level Use Case(s) will not produce a Test Case output on the RTF file.  EA let's me add test cases on the lower level Use Case(s).  This makes our RTF Detail Design documents imcomplete.  I do not want to bring the Use Case(s) up to the highest level as they would not create an easy to read detail design document.  Can this issue be corrected?
Bill Schuyler
"Your vision will become clear only when you can look into your own heart. Who looks outside, dreams; who looks inside, awakes." -- Carl Jung
