Author Topic: Com Exception with Audit  (Read 4191 times)
Stuart Trotter
« on: December 23, 2009, 09:27:22 am »
I'm hoping someone has an idea of how to sort this because it's really frustrating. I have an application which exports xmi from one project and then imports it into another project. The problem I have is that everything works great with auditing switched off in the target project, however if auditing is enabled then a few of the packages are processed but one of the larger ones fails with a COM exception from EA!
The error reads as follows:
The server threw an exception. (Exception from HRESULT: 0x80010105 (RPC_E_SERVERFAULT))
The line of code which produces it is very straightforward and as mentioned before works fine without auditing:
project.ImportPackageXMI(previousPackage.PackageGUID, xmiFileName, 1, 0);
Any ideas would be greatly appreciated.
Stuart
Re: Com Exception with Audit
« Reply #1 on: December 23, 2009, 06:25:32 pm »
Stuart,
You better report that to Sparx though the official channel using the link on the bottom of the page.
