Author Topic: transparent elements in UI diagram  (Read 6610 times)
hb01
  • think before you code
« on: October 27, 2005, 08:28:31 am »
Is there a way to make a panel transparent on a screen in a UI diagram?
I tried importing transparent png's, but that did not work. The color selection does not show an option for transparency.
Hans
Hans
Re: transparent elements in UI diagram
« Reply #1 on: October 30, 2005, 08:32:16 am »
Great, another Hans, und noch dazu einer, der dieselbe Frage hat!
Gruß
Hans
« Reply #2 on: October 31, 2005, 03:00:18 am »
Not neccessarily from a German speaking country ;)
hb01
« Reply #3 on: October 31, 2005, 10:30:16 am »
No I'm not, but I will be happy to try to translate a solution to my problem from any language  ;)
Hans (Boerstra, which is probably an indication of my nationality)
Hans
« Reply #4 on: November 01, 2005, 02:03:24 am »
Hello Hans,
so, I guess, you're not from Namibia..
If there is a notion of transparent color within EA, it's not a transparent color within windows: Try it out within Visual Studio, Photoshop or whatever: that maps right into white! And, if you paint the background in RGB (226,226,226) which is the standard background color in EA, what you'll get upon printing, is a grey background rather than a white one!
Regards
Hans
Hans
« Reply #5 on: November 01, 2005, 02:54:31 am »
Hi all,
I should perhaps explain, why this feature is so important for any
software architect, not only for me alone:
As an architect, I structure the parts, so the design maps 1-1 to
implementation. Now, what I get as input from side of Business Contacts
and Analysts are a plethora of spurious words and
sometimes colorful, ambivalent PowerPoint presentations or Visio
paintings that I in turn can't rely on.
So, I'll have to do things from scratch. Of course, I have my meetings,
in which I'll have to present my design.
Fact is, that Business contacts then keep urging me to make some fancy-
looking pictures from that ("non-technical" as they call them), so that
they may present this to the business.
So, what I'm doing is to copy the digrams and replace the standard symbols
by some colorful clips. That's exactly what the images.zip is good for.
But now, I need to rotate some of the bitmaps and insert some new ones,
and I run into the transparency problem!
Can I convince Business Analsts, Contacts, Management, and business to use
UML2 or even EA? Of course not! So, whether I love or not, I'll have to
turn good, unmistakable UML design into the world of always-smiling colors,
and any means to facilitate that for me will be a great, great help!
Gruß
Hans
