Author Topic: extended referencing capability  (Read 4261 times)
SF_lt
  • The Truth Is Out There
« on: November 10, 2005, 06:13:51 am »
EA 6.0 added "Connecting to a class for which you know the GUID" feature - I propose to go further and add to reference elements by their reference (reference name uniqueness will be user's responsebility), for example:
class
   name="classA"       %TRANSFORM_REFERENCE("reference_to_classA")%
then then creating connectors:
dependency
source
reference name syntax could be in other forms, but this capability would greatly improve build-in EA transforming capabilities
Hope to see this feature ASAP
registertm everything to SparX
Re: extended referencing capability
« Reply #1 on: November 10, 2005, 04:21:58 pm »
I came across a way to do this in the last couple of days.  I still don't recommend it, and I suspect you'll find it less useful than you think, but here it is.  (Example taken from what you wanted to do here.)
File template:
Package
name="test model"
namespaceroot="true"
%list="Class" @separator="\n\n" @indent="  "%
%Class__Dependency%
Class template:
%elemType%
%TRANSFORM_REFERENCE( className, "IgnoreGUID" )%
%TRANSFORM_CURRENT()%
Class_Dependency template:
Dependency
%TRANSFORM_REFERENCE( "MyDependency" , "IgnoreGUID" )%
Source
%TRANSFORM_REFERENCE( "ClassA" , "IgnoreGUID")%
Target
%TRANSFORM_REFERENCE( "ClassB" , "IgnoreGUID" )%
Note that what I've done here is specified a guid that is the same across all references.
« Last Edit: November 10, 2005, 04:24:30 pm by simonm »
SF_lt
« Reply #2 on: November 16, 2005, 10:39:55 am »
yeah, thanks for the workaround - that's how is called temporary solution in QA ;)
however, I still propose Sparx to implement this referencing totally independently from the other transformation elements.
I suppose, it could have one of the forms:
Target { %TRANSFORM_REFERENCE( "ClassB" ) }
or
Target { XRef( name="ClassB" ) }
or many other possible forms.
Right now instead of the magic work "IgnoreGUID" using packageGUID ;)
