Author Topic: Problem: ea6 stereotype.table atribute order  (Read 4632 times)
roman
  • good luck ;-)
« on: November 24, 2005, 06:18:42 am »
this suggestion i adress to the moderator.
This are the Ctrl-T pictures of the same ea-file. In version 6 the order is not the same as in the F9 atribute window and so i get different diagrams of the same file.
This behavior i see by all tables in the file.
Must i go back to ea5 or is there some another way?
R.S.V.P.
roman
Re: Problem: ea6 stereotype.table atribute order
« Reply #1 on: November 24, 2005, 12:57:44 pm »
Hello roman.
EA 6.0 introduced an option to sort attributes and operations by name.  You can turn this off by unchecking 'Sort Features Alphabetically' on the 'Objects' options page.  (The column heading instead of showing the stereotype can be turned off too by unchecking 'Group Attributes by Stereotype'
« Reply #2 on: November 25, 2005, 12:36:06 am »
Hi Simon,
you might think about the option to make this diagram-specific. In general this is a good feature but not for all diagrams. So why not adding an option to the diagram?
roman
  • good luck ;-)
« Reply #3 on: November 25, 2005, 03:00:29 am »
Hello Simon,
you are right, it works.
I agree to Thomas suggestion.
Thank you,
roman
« Last Edit: November 25, 2005, 03:03:45 am by roman »
