Author Topic: Dockable or at least sizeable "bahavior"  (Read 4041 times)
HaveABeer
« on: December 15, 2005, 03:50:50 am »
Hello!
Some time ago you introduced "initial code" edit box in class opration details. This was done at the cost of reducing the "behavior" edit box. Since I bet that writing initial code by designers is much less common than describing operation behavior, I regret that the "behavior" box is so small. Enlarging the window enlarges only the "initial code" box. I therefore suggest that the proportion between two boxes should be changable.
The ideal solution would make the "behavior" box dockable (the same as "Notes" box).
