Author Topic: drag from relationship view to diagrams  (Read 13032 times)
bwl21
« on: January 15, 2006, 11:27:33 am »
being involved in a reverse engineering project, we have to draw a lot of diagrams from the model. I really would like to selekct a bunch of lines in the releationship view and drag them to the diagram. It would save a lot of time. At least being able to drag on by one.
-bernhard
Re: drag from relationship view to diagrams
« Reply #1 on: January 15, 2006, 01:07:02 pm »
Maybe this will help.
Right click on a class in a diagram and select Add | Insert Related Elements.  There's further information about this available from the help on that dialog.
bwl21
« Reply #2 on: January 16, 2006, 01:47:10 pm »
Hi Simon
no, it does not help. First of all it adds all relationship and not only selected ones.
second, the default way to create aggregations is such that the souce is the whole. Therefore the direction is the opposite. This means that selecting o-> shows the associations while <-O shows the aggregations. This is really a mess.
EA6 has an option to reverse this behavor with respect to aggregations. But it does not seem to work.
To make it more evil, the function right click on relationshiop "Add to diagram" no longer works in EA6. As soon as I move the mouse, the mouse pointer changes back to the arrow and nothing happens.
-bernhard
« Reply #3 on: January 16, 2006, 02:00:03 pm »
Just an idea since it sounded like you were doing something like that.
Regarding aggregations, I've taken this from the help file.
Draw Aggregations Reversed - By default, aggregate and composite connectors are drawn in EA from Source to Target. In some modelling tools they are drawn in the opposite direction. When this option is set, EA will mimic those other tools. (nb All tools will have the parent as the target and the child as the source of the connector, that is a requirement of UML; only the direction of dragging the mouse to draw the connector is changed).
My interpretation is that the direction being opposite is specified by UML.  EA's option just helps people who are used to other tools that draw the aggregation the other way.
Sorry, I don't know what "Add to diagram" option you're refering to.  Could you tell me where it is?
« Reply #4 on: January 17, 2006, 08:42:52 am »
Right click on a relation in the Relations window. There's a popup "Add to diagram". It works for me but obviously not for  bernhard
« Reply #5 on: January 17, 2006, 01:39:08 pm »
I still don't see an add to diagram there, I do see a "Place Target Element on Diagram", which requires clicking on the diagram to place the target.
bwl21
« Reply #6 on: January 17, 2006, 01:58:29 pm »
yes, that's it, and when I call this menu, I get an icon on the mouse pointer. But as soon as I move the mouse, the icon disappears and I cannot add the element to the diagram.
bernhard
bwl21
« Reply #7 on: January 17, 2006, 02:10:13 pm »
I do not see any difference in the behavior, however this option is. As far as I understand, the UML superstructure does not really specify, how an aggregation should be made. I want to drag from the "whole" to the "child" as I want to establish a property of the "whole". Therefore the diamond must be at the source side. I achieve this, by opening the aggregation property, set source to "composite" and target to "none". I would like to have this as default behavior.
« Reply #8 on: January 18, 2006, 03:58:14 am »
Try Tools/Options/Objects/Draw Aggr. Reversed
Additionally search this forum for this topic.
bwl21
« Reply #9 on: January 18, 2006, 04:47:11 am »
I tried this, but it has not the desired effect. What I want is:
1. all properties of a class use the composite class as source. This has the advantage:
 * Relationship view shows the role (which is then denoted at the target)
 * Insert related Elements can be done such that all properties are inserted in to a graphic at once.  As it is now, only associations, can be inserted. If I want aggregations to be in the diagram I also get the classes where the classin question is aggregated to.
2. when I drag an aggregation, the mouse movement should go from "whole" to "part" <-> Source to target
The option you mention, allow to drag from whole to part but still establishes the aggregation with target as comoposition.
-b
« Reply #10 on: January 18, 2006, 06:07:38 am »
I know what you mean, but this has been discussed here in broad some time ago. Sorry for not having the time to search for the related thread(s). Maybe someone else can? The conclusion was that this is not going to be changed for several reasons.
bwl21
« Reply #11 on: January 18, 2006, 01:08:14 pm »
I've heard about that. But it does not make it easier ...
-Bernahrd
sargasso
« Reply #12 on: January 18, 2006, 06:32:24 pm »
Me neither, but as one of the antagonists in the original threads, my arguments were generally that
1) EA actually draws them the way its stated in the UML spec and other tools were wrong. (maybe this has changed in new UML, I dunno)
2) I've got lots and lots (and lots) of models that are drawn that way round - I dont want a new release of EA suddenly interpreting the world the other way up.
3) IIRC - because I said so.  (Just to annoy Paolo).
bruce
« Reply #13 on: January 18, 2006, 07:27:10 pm »
I've just come back from two weeks holiday... So it'll take a lot to annoy me... :-)
I gave on the EA composition connector a long time ago (aside from it's questionable definition, it was full of bugs at the time - I think I gave some examples in the forum). :-X
I just create Associations and adorn them appropriately... (As per the UML specification - bruce)
Cheerz,
