Author Topic: Stereotype display  (Read 5298 times)
Stereotype display
« on: February 22, 2006, 01:51:40 am »
I have the following problem: Classes with stereotype <<control>>, <<boundary>> and <<entity>> display nicely as icons when used in diagrams. For overview purpose this is   what I want and need. But I also would like to draw diagrams where they appear in rectangle notation. Either there is a possibility to do that, then please enlighten my. If not it would be nice to have this option (as already present for Use Cases and Actors).
mbc
  • Embedded software developer
Re: Stereotype display
« Reply #1 on: February 22, 2006, 05:07:23 am »
Hi Thomas
If you open the Diagram Options (double-click on the diagram background) there is an option "Use stereotype icons" that you can uncheck. Would that work for you?
Best regards
Mikkel
« Reply #2 on: February 22, 2006, 06:43:32 am »
Hi Mikkel,
this was too obvious ;D I looked a dozen times over the unchecked options, but never respected the checked ones :-[
