Author Topic: link between uc scenarios and seq diagrams  (Read 4092 times)
malmoth
  • On ne réveille pas un malmoth qui dort
« on: March 07, 2006, 01:38:29 pm »
I'd like that sequence diagrams linked to a use case with a specific link (let's say "is scenario") appear in the scenario tab of the use case property. As it is the case with requirements in the require tab.
« Last Edit: March 07, 2006, 01:52:40 pm by rejaudry »
Malmoth
Re: link between uc scenarios and seq diagrams
« Reply #1 on: March 08, 2006, 01:07:29 am »
You can move it inside the UC in the project view. That would have a similar effect.
malmoth
« Reply #2 on: March 08, 2006, 04:25:20 am »
Are you sure of that ? Because, my seq diagrams already are inside use cases, and I don't see anything in the scenario tab unless I manualy create new scenarios for the use case.
I am using EA 6.1.788
Malmoth
« Reply #3 on: March 08, 2006, 06:40:52 am »
Just name the diagram after the scenario. That should be obvious then. It's not a kind of a real link, though.
malmoth
« Reply #4 on: March 08, 2006, 07:59:23 am »
Indeed, that's what I'm doing.
That's my point. A real link would prevent gaps when renaming scenarios or diagrams.
« Last Edit: March 16, 2006, 01:40:30 pm by rejaudry »
Malmoth
