Author Topic: Create boundary symbol in a diagram  (Read 4868 times)
MagnusH
« on: January 13, 2010, 04:59:49 pm »
I have problem with creating a solid boundary symbol in a diagram. I cannot find any method to change it from nofilled. Any idea?
Magnus
Re: Create boundary symbol in a diagram
« Reply #1 on: January 13, 2010, 07:07:15 pm »
Magnus,
In the database this is seems to be related to the column BorderStyle on the t_object table.
If you can access it through the API then it will probably be through the StyleEx field.
PS. The way I usually try to figure this out is to create a new eap file and create only the objects I'm interested in. (in this case two boundaries) and then use MS Access to figure out where EA has stored which information.
MagnusH
« Reply #2 on: January 14, 2010, 02:10:03 am »
Geert,
Thanks for the quick response. Yes, I found the column as well but as far as I can see after testing the StyleEx is not containing this information. I give up.
Magnus
« Reply #3 on: January 14, 2010, 09:16:36 am »
Geert,
Magnus
Hi Magnus,
The boundary type is configurable on a per-diagram basis (I think).  Check out ObjectStyle in t_diagramobjects.
« Last Edit: January 14, 2010, 09:19:13 am by PaoloFCantoni »
MagnusH
« Reply #4 on: January 14, 2010, 06:14:45 pm »
Hi Paolo,
I found it :-)
It's in the properties Attribute of the boundary element. It's a collection of Property attributes and the name to search for is "BorderStyle". If I change the value to "Solid" it works as expected!
A piece of Perl code:
sub ChangeBorderStyle
  my ($self, $Element, $Style) = @_;
  for my $PropIndex (0 .. $Element->{Properties}->{Count}-1)
    my $Property = $Element->{Properties}->Item($PropIndex);
    if ($Property->{Name} eq "BorderStyle")
      $Property->{Value} = $Style;
Thanks for the help,
Magnus
