Author Topic: ENHANCEMENT: resizing multiplicity/constraint  (Read 4293 times)
SF_lt
  • The Truth Is Out There
« on: May 29, 2006, 03:58:51 am »
if there is a set constraint, then by resizing association multiplicity text, there should be possible to align multiplicity with the constraint on the same line.
Note: aggregation is handled differently than association ;-) sometimes reacts to ordered, sometimes not...
Now constraint always stays below multiplicity
{set}
Would be nice to get:
* {set}
If multiplicity is ordered (checkbox is checked), then we have:
{set}
{ordered}
Would be nice to have a chance to resize to:
* {set, ordered} OR * {set; ordered}
Note2: currently EA doesn't allow to join constraints
Copying moved to separate thread:
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=suggestions;action=display;num=1148904862;start=0#0
I'm almost sure, that Paolo will say something uniquetm about such EA behaviour  ;D
« Last Edit: May 29, 2006, 06:51:51 am by SF_lt »
registertm everything to SparX
Re: ENHANCEMENT: resizing multiplicity/constraint
« Reply #1 on: May 29, 2006, 04:27:03 am »
Actually, I suspect Paolo will say something consistent (CCC!) about such unique behavior.
Otherwise, SF_it I'm on the same wavelength.
However, you seem to be talking about two different suggestions. Perhaps you should break the second out into its own thread, so that comments etc. could be kept with each one.
