Author Topic: Export/Import support for numbered items  (Read 5815 times)
Mikael
« on: May 31, 2006, 10:51:26 pm »
When creating numbered items in RTF templates they work just fine until you try to export a template to use in another EA project, the style containing numbering seems to be lost during import and exporting.
Try this:
1. Right click Resource View > Tempates > RTF Style Templates. Select Create RTF Style Tempate.
2. Select a name and choose none in the Copy template field.
3. Create 2 nested numbered styles under Edit > Edit Style.
4. Export the template to RTF and close template in EA
5 Reopen template and import RTF file you created in step 4.
When this is done only the first level of numbering still works, the second level does not.
I hope you can fix this, becouse we have alot of trouble getting our standard templates to work in new projects.
Thanks in advance
