Author Topic: Bug about Active Class!  (Read 4156 times)
gazxfe
« on: June 25, 2006, 11:45:44 pm »
Hi:
  I find a bug about active calss. When I set a Class as an active class, the style of class doesn't change.
Andy
Example:
Normal Class
Active Class
Re: Bug about Active Class!
« Reply #1 on: June 26, 2006, 02:36:25 am »
Works OK for me.  (build 791)
I see what you see in your example.  Are you NOT seeing what you've posted?
If you are, what is your exact problem with what you are seeing?
gazxfe
« Reply #2 on: June 27, 2006, 03:35:14 am »
Thank you ! I found out how to do that.
Properties-->General-->Advanced-->is Active
The method I was used is setting the attribute  'isActive'=True(in Customer Properties).
Could you tell me what's different about the two attributes?
Thank you
Andy.
« Last Edit: June 27, 2006, 03:37:37 am by gazxfe »
« Reply #3 on: June 27, 2006, 04:51:56 am »
Thank you
Andy.
Hi Andy,
This is similar to the Multiplicity versus Cardinality question you'll find I posted in the forum a long time ago.  One works, one doesn't.
I can't explain why there are two IsActive concepts.  :(
Normally the Custom properties are for UML attributes not handled directly by EA (see my post on this elsewhere).
I'm afraid EA's unique user interface strikes again...   ::)
