Author Topic: Custom Compartments  (Read 9852 times)
Custom Compartments
« on: December 23, 2007, 05:15:39 pm »
Hi All,
I've been having a go at creating custom compartments. Here's some code (VB.Net) that seems to work - it creates a deployed artifacts compartment for node elements...
Function EA_QueryAvailableCompartments(ByVal Repository As EA.Repository) As Object
   EA_QueryAvailableCompartments = "deployed artifacts"
End Function
Function EA_GetCompartmentData(ByVal Repository As EA.Repository, ByVal sCompartment As String, ByVal sGUID As String, ByVal oType As EA.ObjectType) As Object
   If Repository Is Nothing Then
       EA_GetCompartmentData = ""
       Exit Function
   End If
   Dim el As EA.Element
   el = Repository.GetElementByGuid(sGUID)
   Dim sData As String = ""
   Dim sCompartmentData As String = ""
   If el.Type = "Node" Then
       Dim con As EA.Connector
       For Each con In el.Connectors
           If con.SupplierID = el.ElementID Then
               If (sCompartment = "deployed artifacts" And con.Type = "Deployment") Then
                   Dim art As EA.Element
                   art = Repository.GetElementByID(con.ClientID)
                   If art.Type = "Artifact" Then
                       sData = sData + "Data&_eq_^" + art.Name + "&_sc_^"
                       sData = sData + "GUID&_eq_^" + art.ElementGUID + "&_sc_^,"
                   End If
               End If
           End If
       Next
       If sData <> "" Then
           sCompartmentData = sCompartmentData + "Name=" + sCompartment + ";"
           sCompartmentData = sCompartmentData + "OwnerGUID=" + sGUID + ";"
           sCompartmentData = sCompartmentData + "Options=SkipIfOnDiagram&_eq_^1&_sc_^"
           sCompartmentData = sCompartmentData + "CompartmentData=" + sData + ";"
       End If
   End If
   EA_GetCompartmentData = sCompartmentData
End Function
Happy holidays,
Neil
Re: Custom Compartments
« Reply #1 on: December 23, 2007, 08:00:16 pm »
Thanks for that Neil,
Can you post it on the Wiki?
And all the best for the season to you too!
neuron
« Reply #2 on: January 25, 2010, 08:22:52 pm »
how can I print compartment value in shapescript ?
neuron
