Author Topic: problem with encoding in Model Issues  (Read 8534 times)
ernest
« on: July 11, 2006, 03:11:31 am »
I have a problem with some czech characters in editing model issue. In Maintenance window I can add a model issue with czech characters, but when I save the issue and reopen the dialog the Name field contains some wrong characters.
I tried these characters
and after saving and reopening the dialog I got this
Will you help me?
I have EA 6.1.791
ernest
-ernest
Re: problem with encoding in Model Issues
« Reply #1 on: July 12, 2006, 05:41:53 am »
There have been posts regarding Czech chars here. Have you searched for them (can't actually help you)?
ernest
« Reply #2 on: July 13, 2006, 02:48:13 am »
yes, I tried searching for string "czech" during last year at the forum and I found only "Problem with RTF report for Model Issues". I think, this is another problem.
Does anybody have the same problem?
-ernest
Jan ´Bary´ Glas
  • Bary
« Reply #3 on: July 14, 2006, 12:15:59 am »
It works well for me, build 6.1.792.
Cannot replicate.
Problems with Czech I suffered before:
when Czech (localized) MS Windows w/EN keyboard - problems with RTF generation (already fixed)
not described problem w/ RTF generation (from time to time it behaves strange w/custom templates, still no idea why, working on it)
Conclusion: I have problem with nothing inside the EA (considering Czech).
Jan 'Bary' Glas
ernest
« Reply #4 on: July 18, 2006, 04:34:13 am »
In EA version 6.1.792 the problem still persists. I tried another computer in our company (with the same version), and they have the problem too. We have Unicode version installed.
I don't have another problem with czech characters except this and the behavior which Bary described.
Could you remove the unpleasant behavior? Has anybody some idea, what to do/test?
-ernest
Jan ´Bary´ Glas
  • Bary
« Reply #5 on: July 19, 2006, 10:48:14 am »
 ernest, still cannot repeat.
what system do you have? (I have MS Windows XP English version.)
Jan 'Bary' Glas
« Reply #6 on: July 19, 2006, 03:06:37 pm »
I'm not completely sure of your problem, but if you're using EAP files make sure that you're using JET 4.  (Tools | Options| General)  You may also need to get a JET4 base model.
If you're using a repository, make sure that the repository is set up to handle unicode characters.
ernest
« Reply #7 on: July 20, 2006, 05:45:49 am »
I'm running WinXP Pro Cze SP2 and as a repository we have MS SQL 2000 Standard Edition SP3, Server collation SQL_Czech_CP1250_CI_AS. Database collation is the same.
ooops, I was looking into the database, into the table t_objectproblem and I noticed that the column Problem has varchar datatype whilst the column ProblemNotes and other has ntext and nvarchar. It's possible that this could cause the problem?
-ernest
« Reply #8 on: July 21, 2006, 11:10:09 am »
That sounds entirely likely.
ernest
« Reply #9 on: July 24, 2006, 12:10:00 am »
Yes, it works! Changing the datatype of the column from VARCHAR to NVARCHAR, solved my problem.
Thank you everybody
-ernest
Jan ´Bary´ Glas
  • Bary
« Reply #10 on: July 24, 2006, 12:51:34 am »
Superb, helps for the future in similar cases. Thanks a lot.
Jan 'Bary' Glas
« Reply #11 on: July 24, 2006, 01:49:28 am »
Thank you everybody
As you can see, the Sparxians do monitor this forum, but it may be best to let them know formally...
ernest
« Reply #12 on: July 24, 2006, 02:07:26 am »
I wanted to discuss the problem first.
And now, is it necessary to report a bug or will you solve the problem without the report?
-ernest
« Reply #13 on: July 24, 2006, 04:58:41 am »
BTW, remember that this (changing from 8-bit to extended character types) will work - with appropriate adjustments - for Oracle, SQL Server, and Sybase repositories. I suspect similar adjustments will also work with the other repository types.
