Author Topic: Move connector between elements  (Read 5533 times)
Dave_Bullet
« on: July 31, 2006, 02:03:13 pm »
Say you have an activity diagram with activities A, B with a control path from A -> B.  You want to add activity C and have the following path A -> C -> B
It would be nice to be able to:
1. Grab the connector between A -> B at the B (target end)
2. Drag it across to C
thus deleting the connection from A -> B and "re-using" it to make A -> C
The above should also work for like minded relationship and elements types. (ie. associations between classes etc...)
Saves having to delete and re-add new connectors.
Cheers,
David.
Re: Move connector between elements
« Reply #1 on: July 31, 2006, 02:56:11 pm »
Hold down shift, click on the connector near B, click on C.
Takeshi K
    • Sparx Systems Japan
« Reply #2 on: July 31, 2006, 02:56:56 pm »
Hello David,
You can switch connector end by clicking end of
connector with SHIFT key and click target element.
Hope this helps.
t-kouno
t-kouno
Dave_Bullet
« Reply #3 on: July 31, 2006, 07:41:01 pm »
Thanks.  Exactly what I was after - must check the help again for it!
Cheers,
David.
