Author Topic: "Show Realized Interfaces" - better UI,  (Read 10467 times)
estaub
« on: August 24, 2006, 11:17:47 am »
It would be nice if the class context menu item "Add Embedded...Show Realized Interfaces" was more easily used.  There are probably other commands in this category - if you address this, I'd look for the other cases too.
1.) Because it's only accessible as a context-menu command, the command can't be accessed from the Customize... UI, so it can't be put on a toolbar or bound to a key.  This is probably true of all commands that are on the context menus and not on the toolbar menu.
2.) Keyboard access does not work.  Try it.  Context-menu-key + B goes straight to a different dialog box, I think because there's no accelerator keys assigned to the rest of the keys in the submenu.
3.) There are a lot of actions that could be applied to multiple objects at once that aren't accessible from the context menu if you multi-select.  This is one of them.
-Ed Staub
Re: "Show Realized Interfaces" - better
« Reply #1 on: August 24, 2006, 03:00:17 pm »
1) Look at Element | Advanced | Override Implementation.  On my computer it has the keyboard shortcut Ctrl+Shift+O.  This is mentioned at http://www.sparxsystems.com/EAUserGuide/index.html?overrideparentoperations.htm
2) You can use keyboard arrows to navigate the context menu.  Mind you, I can't find it in the context menu anyway.
3) It seems to me that this is also something that doesn't make sense with multiple classes selected.
estaub
« Reply #2 on: August 24, 2006, 03:58:10 pm »
>> 1. ) Look at Element | Advanced | Override Implementation.
This is a totally different function.  The "Show" function controls whether a lollipop is shown on the class.  The "Override" function implements overrides in subclasses.
The only way to reach "Show Realized Interfaces" is through the context menu (I'm pretty sure), so I don't know what you're thinking of... maybe you've confused "Override" with "Show" still?  Click on a class, now, without using the mouse, try to find a sequence of keystrokes that will lead you to "Show Realized Interfaces".
Here's how to reach it with the mouse:
 1.) right click on class
 2.) Select "Add Embedded".
 3.) Select "Show Realized Interfaces".
Maybe this is the "Show" vs. "Override" confusion again.  Example: I have six classes that all implement interfaces, and I want to show lollipops on all of them.  Given items 1 through 3 above, it's pretty tedious.  If multiselect worked, I wouldn't care as much about the other two issues.
-Ed Staub
« Reply #3 on: August 24, 2006, 04:53:16 pm »
Sorry, ignore all of my comments except for being able to navigate the context menu with the keyboard arrows.  I was too quick to respond and too slow to think.
