Author Topic: <<decisionInput>>  (Read 20574 times)
Harbottle
<<decisionInput>>
« on: September 27, 2006, 06:46:32 am »
Does EA support <<decisionInput>> on decisions? I can't seem to find it, and am loathe to attempt to use "Notes" and bodge it.  I'd like to be able to link an existing action to a decision.
I can't work out how to create a "grouping" of input parameters on an activity in order to implement an "Or" relationship...
Jan ´Bary´ Glas
  • Bary
Re: <<decisionInput>>
« Reply #1 on: September 27, 2006, 07:08:51 am »
Superstructure defines this:
I can do it this way:
But the fact is, that I do not know about this feature in EA (I used a note).
HTH, Bary
Jan 'Bary' Glas
« Reply #2 on: September 27, 2006, 07:55:32 am »
Superstructure actually defines «decisionInput»
to be rendered as a Note.  You can make a "feature Linked" note to a constraint of type decisionInput.  The problem you have is that EA doesn't allow the stereotyping of Notes via the UI, but you can do it via the database directly.
Creating such a note and setting the stereotype will get the rendering Bary created (except that the «decisionInput» will be a true stereotype).
Harbottle
« Reply #3 on: September 27, 2006, 08:23:32 am »
Thanks, I did this and it works.
« Last Edit: September 27, 2006, 08:24:05 am by Harbottle »
« Reply #4 on: September 27, 2006, 03:36:10 pm »
You can use the Properties window (Alt+1).
« Reply #5 on: September 27, 2006, 03:45:27 pm »
OK,  thanks for that Neil, BUT it does need to be on the Properties dialog as welll...
