Author Topic: Other Notes improvements...  (Read 4597 times)
« on: September 27, 2006, 07:04:34 pm »
Under the Element menu (both Main and Context) can we have an Add - Feature Linked Note item?  That would place the note similar to the Add - Note item and then immediately open the linked note dialog?
Also, Notes don't seem to respond to the resize function [Alt+Z] - they need to.
If you Attach a Note or Constraint to a connector, the note link is not selectable (and therefor NOT movable nor pinable) - the element one is... This needs to be fixed.
Lastly, can some thought be given to optionally displaying any notes on a connector to the connector (similar to the Notes compartment I've asked for elsewhere).
At a minimum, we need to be able to display the Notes of a connector as a Feature Linked Note (on the connector)
Voting starts Now...
[Edit: Add the ability to add the Diagram Note (NOT the Property Note) directly from the menu]
« Last Edit: September 27, 2006, 07:11:41 pm by PaoloFCantoni »
Re: Other Notes improvements...
« Reply #1 on: October 02, 2006, 07:16:44 pm »
Another suggestion (which I think I've added a elsewhere...
If a Note is a linked note (and therefore not modifiable), then please render the text in the Note window [Ctrl+Shift+1] as disabled so it is clear that you can't change it...
Even better, put some indication as to which element this note is linked to (and how).
« Reply #2 on: October 02, 2006, 07:32:43 pm »
This one is pretty important...
In fact, I think it's a bug not a suggestion...
The Note window [Ctrl+Shift+1] does not render correctly.
Even though Unicode support should (now) be ubiquitous throughout EA, the Note window does not render Unicode correctly - it seems stuck in the US ASCII past.
The correct characters are entered via the window (for example a large bullet: ●) and are stored in the repository, and rendered correctly one a linked Note in the diagram - but NOT in the Notes window where they appear as half-blocks: ▌.
This needs to be fixed ASAP...
« Last Edit: October 02, 2006, 07:33:15 pm by PaoloFCantoni »
« Reply #3 on: October 02, 2006, 09:22:16 pm »
Note names should be available on the Notes Dialog.  The default should be: Note (as at present).
Jan ´Bary´ Glas
  • Bary
« Reply #4 on: October 02, 2006, 11:14:51 pm »
Yes the default should always be UML syntax. A Comment is an Element not a NamedElement. It may be a part of an Element, it may annotate a set of Elements. It's only attribute is body: String.
Jan 'Bary' Glas
« Reply #5 on: October 03, 2006, 12:02:53 am »
Bary,
I'm talking here about the EA Note Element (which is EA's mechanism for instantiating UML Comments).
As far as UML is concerned, the Name Note (as at present) is incorrect - so I'm just saying if you're going to break the rules, then do it in a useful way.   ;)
Whether the name is rendered onto the diagram is another matter.  But I've found that occasionally giving notes a name is useful as they summarise the semantic content of the note.
And (thinking out loud) if you could give them a name, you could reduce the size of the note (in an outlining sense) and have a little
  • /[-] outliner control to show or not show the detail.
    [size=0]©2006 Paolo Cantoni, -Semantica-[/size]
