Author Topic: CUTE: Chercher le connecteur  (Read 3868 times)
« on: October 12, 2006, 07:34:40 pm »
When you drag a class with a reflexive association onto a diagram, the default reflexive drawing is rendered.  Everything is on top of the other...   :-X
If you have more than one reflexive then it's really hard.   ::)
You have to move everything out of the way to get at the connector to re-size it then put everything back...
It would be good if we could set up default "pinning" for connectors on a shape.   8)
However, in the interim, I (accidentally) discovered a useful trick...  Position the mouse over where you think the connector is (uder the overlaying text boxes), and then hold the [Ctrl] key down and [Left Click].  The connector and NOT the overlaying text boxes will be selected...  Cute!   ;)
Voting for Default Pinning starts now...
[WARNING:  Make sure you are over the connector... Otherwise holding down the [Ctrl] key and clicking will adds whatever the last element placed on the diagram was... - Edit as a result of the next post]
« Last Edit: October 12, 2006, 08:05:39 pm by PaoloFCantoni »
Re: CUTE: Chercher le connecteur
« Reply #1 on: October 12, 2006, 07:47:15 pm »
Actually, Ctrl+Click on the diagram (excluding a connector or existing element) adds whatever the last element placed on the diagram was, something that is a popular feature.
Ctrl+Click on a connector will place a waypoint at that position and select the connector.  However, as waypoints have been disabled on reflexive connectors because it makes them too hard to handle, it just selects them.
« Reply #2 on: October 12, 2006, 08:08:38 pm »
Thanx for clarifying that Simon.
For the record, if you have a Direct line, then no waypopint is created with [Ctrl+Click] - but the line is still selected.
« Reply #3 on: October 12, 2006, 08:26:58 pm »
Right, so what I should have said is that Ctrl+Click on a custom style connector will place a waypoint.  Reflexive, direct and auto-routing connectors will only be selected.
