Author Topic: Support for Team Foundation Server  (Read 4956 times)
john.roome
« on: June 01, 2006, 09:03:37 pm »
I was wondering whether EA will be supporting Microsoft's Team Foundation Server's Source Control system.  Also is there a plan to support VSS 2005?
regards
John
Marvis
  • Creativity is allowing yourself to make mistakes.
Re: Support for Team Foundation Server
« Reply #1 on: August 03, 2006, 12:54:44 am »
There is a solution from Microsoft sinds 6/23/2006.
Look here:
http://www.microsoft.com/downloads/details.aspx?FamilyId=87E1FFBD-A484-4C3A-8776-D560AB1E6198&displaylang=en#QuickInfoContainer
If you install this plugin, you can select a SCC provider. There you should see the option for Team Foundation.
To install this plugin, you must have the TFC installed.
john.roome
« Reply #2 on: August 06, 2006, 03:44:39 pm »
Thanks for that.
Have you tried this, I spoke to Sparx Support and although this used to work it doesn't with the final release of Team Foundation.
cheers
John
Marvis
« Reply #3 on: October 17, 2006, 06:25:08 am »
Hello.
Yes, we have tried this on the final release (Trial). You get a lot of comment boxes before your checkin. So, the process is not perfect but it works all right.
Also tried EA version 6.5 with TFS support, but couldn't checkout packages.
Do you have an other solution already?
