Author Topic: Bug? – single element RTF doc omits child info  (Read 7231 times)
erixon
« on: September 22, 2006, 07:48:29 am »
BACKGROUND INFO:
I am using EA version 6.1.790.
My Use Case View has the following general layout:
Package
-Use Case Diagram
--Use Case
-----Activity Diagram
----------Initial
----------Activity1
----------Activity 2
----------Activity 3
----------Final
--Use Case
----------Initial
----------Activity1
----------Final
--Use Case
----------Initial
----------Activity1
----------Final
Each Use Case element may have constraints, scenarios, requirements and files.
Each Activity element may also have some or all of these.
When I generate RTF documents from the Package level, my RTF templates recursively return all this information very nicely since they include the <<Child Elements>> section.
PROBLEM DESCRIPTION:
However, when I open the Use Case Diagram, select a single Use Case element, and generate RTF documentation, the information returned for the Use Case element is fine but the information for the child elements does not include scenarios, constraints, internal requirements or files.  It DOES include element name and notes, and external requirements though.
This occurs when using existing templates in EA as well as my own customized templates.
I have been unable to find any RTF help file or documentation that describes this behavior.  Is there something I am missing or is this a bug? This is a significant limitation in reporting capability as we need to be able to generate detailed documentation on either one or multiple use cases (i.e. single element or package).
Here is an example of the RTF template layout:
package >
element >
{Element.Name}
{Element.Notes}
requirement >
{ElemRequirement.Name}
< requirement
external requirements >
{ElemExtRequirement.Name}
< external requirements
constraint >
{ElemConstraint.Name}
< constraint
scenario >
{ElemScenario.Scenario}
< scenario
file >
{ElemFile.FilePath}
< file
child element >
< child element
< element
< package
eAndy
Re: Bug? – single element RTF doc omits child info
« Reply #1 on: September 25, 2006, 06:54:44 am »
I think I am experiencing a similar or the same problem.
I have a requirement that owns other requirements.
The parent requirement is linked (via Realization) to a use case.
When the use case detail is dumped via RTF generation it shows the parent requirement but does not show the child (owned) requirements.
I think I have to explicitly link the child requirements to the use case.
« Last Edit: September 25, 2006, 06:55:09 am by eAndy »
« Reply #2 on: September 25, 2006, 09:51:39 am »
How does the parent requirement "own" its children? Are you using an aggregation or a generalization?
eAndy
« Reply #3 on: September 25, 2006, 04:25:56 pm »
drag a requirement and drop it onto a another, it will fall under the one you dropped it onto.
if you link the parent to a use case via a realization you'll see in the hierarchy window that the parent requirement 'owns' the child requirement.
Jan ´Bary´ Glas
  • Bary
« Reply #4 on: September 26, 2006, 12:06:44 am »
eAndy: There is always something to learn. Cool feature. Thanks.
Jan 'Bary' Glas
cyates
« Reply #5 on: October 25, 2006, 12:03:14 pm »
Besides the hierarchy window, what other ways can the relationship (aggregation) be seen by the user?  I am looking for ways to see these relationships when I use the RTF capabilities of the system at the very least.
Jan ´Bary´ Glas
  • Bary
« Reply #6 on: October 25, 2006, 11:30:38 pm »
You may generate for any Element via its Connector related Source and/or Target Elements.
connector >
source >
element >
{Element.Name}
< element
< source
target >
element >
{Element.Name}
< element
< target
< connector
Jan 'Bary' Glas
