Author Topic: Autodeletion should "dirty" diagram  (Read 4043 times)
« on: November 27, 2006, 10:37:06 pm »
We've observed that if an object is deleted from an open diagram by virtue of an external action (such as deleting a package that contains the object).  Although the diagram is changed, EA does not mark the diagram as "dirty" (placing the * to the left of the name on the tab).
We think this should be changed.  That way, if you refactor the model and have a diagram that contains stuff that should be retained after the deletion, if it is set dirty afterwards, you know the refactoring wasn't correct.
Thoughts?  Votes?
[size=0]©2006 Paolo Cantoni, -Semantica-[/size]
« Last Edit: November 27, 2006, 10:37:39 pm by PaoloFCantoni »
sargasso
Re: Autodeletion should "dirty" diagram
« Reply #1 on: November 28, 2006, 04:52:33 am »
Just a clarification query.
When you do that - and then close the 'affected' diagram  - does it ask whether to save it?  (NB this is different to marking it dirty!)
Also, is there any impact you have observed when that  diagram is reopened?
I ask because this may explain something I've been scratching my bald spot over.
bruce
20 Minute after EDIT: On second thought, no this isn't the same weirdity in behaviour or the same feature request.  But I may leave it here just to piggy back in the hope that someone has seen some inconsistency in having mutliple diagrams open and - after deleting an element from one,  it reappears as a "project browser" orphan - i.e it's not visible in any diagram, nor in the browser, but it sure as heell is there in the t_objects table???!!!///
« Last Edit: November 28, 2006, 05:06:03 am by sargasso »
« Reply #2 on: November 28, 2006, 05:37:38 am »
NO...
NO...
