Author Topic: BUG: Keyword, keyword wherefore art thou keyword?  (Read 4067 times)
« on: November 30, 2006, 07:42:09 pm »
If an edge has a defined UML keyword (such as an Information Flow: «flow» - see Analysis Toolbox).  If you subsequently add a stereotype, the keyword disappears.  To "get it back" you have to add an identically named stereotype - which is wrong...
UML keywords are not stereotypes.  If both a keyword and (one or more) stereotype(s) are present, then both must be visible.
The [size=13]UML 2.1 Superstructure (interim)[/size] Specification doesn't seem to be clear on whether they are to be rendered as:
«keyword» «stereotype, stereotype»
or as:
«keyword, stereotype, stereotype»
But I suspect the keyword should always come first.
This needs to be rectified.
Re: BUG: Keyword, keyword wherefore art thou keywo
« Reply #1 on: November 30, 2006, 08:07:18 pm »
or as:
Annex B, p717 says:
If multiple keywords and/or stereotype names apply to the same model element, they all appear between the same pair of guillemets, separated by commas
« Reply #2 on: November 30, 2006, 08:31:01 pm »
Thanks for that Neil, that's definitive, but not normative since it doesn't specifiy the order...
I still contend the keyword(s) should come first.
« Reply #3 on: November 30, 2006, 08:37:29 pm »
Totally agree!
