Author Topic: About adding message in Communication diagram  (Read 7919 times)
Yakun Wang
  • Good tree can produce good fruit.
« on: March 15, 2007, 11:35:17 pm »
In EA 6.5, when adding message between objects in Communication Diagram, an association link should be created firstly, then message can be added to the link. "The association link" is confusing with "association concept" in Class diagram. I think it is better to replace the association  icon with a new message icon into Communication Toolbox since it has different appearance from which in Sequence Diagram.   ;)
God is always with us!
Re: About adding message in Communication diagram
« Reply #1 on: March 16, 2007, 04:23:03 am »
The [size=13]UML 2.1 Superstructure (interim)[/size] Specification in Table 14.4 Graphic paths included in communication diagrams notes that the only edges to be shown on a communication diagram are Messages.
The EA help file says:
Communication messages in Enterprise Architect are always associated with an association link between object instances. Always create the association link first - then add messages to the link.
 and this is YaKun's experience.
However the issue is exacerbated by EA's UI (Unique Interface).  The Quick Linker uses the terms Link and the Toolbox uses the term Associate.  A Link is really an instance of Association (used to join two instances of Classes).  It may be better if EA standardized on Link (as shorthand for Association Link) and when the properties dialog the the link you've just created was captioned Link Properties rather than Association Properties.
Just why a message has to be associated with a Link is not clear to me, and certainly not implied by the UML specification (as I read it).  However, be that as it may,  It is disconcerting to right click in the message just associated and find the menu item Collaboration Properties... then, when I select it, the dialog is captioned Message Properties.
Now it seems fairly clear from the behaviour of the message "thing" and the Diagram|Set Visible Relations...  [Ctrl+Shift+I] that there are two relations in play here - so again, why the requirement for the Link?
Oh, by the way, the message edges on the communication diagram never have arrow heads.  So they should be marked Direction: Unspecified
Consistency, Consistency, Consistency! TM
« Last Edit: March 16, 2007, 04:25:11 am by PaoloFCantoni »
