Author Topic: C# class, method and member variable attributes  (Read 5117 times)
d_p_robinson
« on: March 23, 2007, 04:38:24 am »
C# Reverse engineering does not seem to generate any model artifacts for C# class, method and member variable attributes ([] notation).
For example, code:
using System;
using System.Collections.Generic;
using System.Text;
using NUnit.Framework;
namespace TddSample
   [TestFixture]
   public class CalculatorTests
       [Test]
       public void testAddZeroToZero ()
           // Code for tests
'Test' and 'TestFixture' do not appear in the model. I have also imported the NUnit.Framework binary (exposes TestAttribute and TestFixtureAttribute classes) and this has no effect either.
David Robinson
Re: C# class, method and member variable attribute
« Reply #1 on: March 25, 2007, 01:24:41 pm »
Have a look at the C# modeling conventions in the help.  (http://www.sparxsystems.com.au/EAUserGuide/index.html?csharp_conventions.htm)
They are in tagged values.
d_p_robinson
« Reply #2 on: March 25, 2007, 11:20:59 pm »
I've checked the tagged values in the C# conventions page and these don't apply to C# attributes. In the example in my post a C# '[]' attribute can be applied to a class, interface, property, method or member variable. An attribute is an instance of a class attached as metadata to the item to which it refers. The C# page refers to modifiers such as const, delegate etc that are part of the C# language. C# attributes are user-defined extensions. I'm not sure how these would be expressed in EA as they're not really stereotype - for example they can take parameters.
David Robinson
« Reply #3 on: March 26, 2007, 02:19:45 am »
Note that this also applies to VB.Net. Attributes can be applied to the same range of elements, and can take parameters. The concept is common across many .Net compilers.
« Reply #4 on: March 26, 2007, 12:52:25 pm »
And as I said, in EA they are stored in tagged values.
On any class, interface, attribute, operation or parameter you can add a tagged value "Attribute" = "[TestFixture]" (or whatever your attributes are) and EA will generate them to code.
d_p_robinson
« Reply #5 on: March 26, 2007, 10:54:31 pm »
Thanks. I hadn't spotted the Tagged Values window, I was only looking in the Class and Methods dialog boxes from where there is no reference to tagged values and in the class diagram where there is no indication of a tagged value being attached.
David Robinson
